Problem related to PDMlink 10.2 and PDMLink 11.0: it's possible to check in unverified family table. It is needed to implement the PDMLink options, which enables to choose if unverified family table can be checked in or not. Currently we have to invest additional effort to create specific triggers / listeners, which can prevent check in unverified family tables. Options available in Creo:
are not sufficient. We need the option in PDMlink.
Training issue!
If your users are ignoring the warnings, the software is doing all it can to inform them of an issue.
The config.pro option actually does a verify of the family table when saved, so that 'solves' the problem since when checked in, the family table will have been verified.
Please explain what other issues you are having that the software is not currently catching.
