Javascript in MVC Table that calls an action
dullnigAlex
Usecase:
I have an MVC Table like following:
Is there a way to implement a Javascript function that calls an Action on doubleclicking a row in the first column.
It should call the same Action like the following one:
Alex
hlafkir
(To:dullnigAlex)
HI Alex,
Hope you are fine.
Why don't you use in an easier way the follwing :
http://support.ptc.com/help/windchill/wc111_hc/whc_en/index.html#page/Windchill_Help_Center/WCCG_UICust_PresentInfoUI_ConstructRender_JCATable_CP11.html
Configuring Table — Enabling a Row Selection
Making the rows selectable can be done by using setSelectable() on table config. To make the table non-selectable the value must be set to “false”. By default, table is selectable.
For example:
For setting non-selectable table.
ComponentConfigFactory factory = getComponentConfigFactory();
TableConfig table = factory.newTableConfig();
table.setSelectable(false);
I think it is exactly the same as you are requesting, isn't it ?
Hicham
I'm not aware of a double click. Would be cool if that works. Have you opened a ticket at PTC?
Perhaps you can register your own table event. Have you checked the JS documentation?
