POST /ProblemReports folder location
Dobi
17-Peridot
Version: Windchill 13.0
Use Case: Creating a problem with REST API but can't adjust the folder location in the API body.
Description:
Not sure how to use the syntax perhaps but I tried everything that comes to mind and I'm not getting the expected result.
Here:
Context@odata.bind is the Context (wt.pdmlink.PDMLinkProduct:xxx)
Folder@odata.bind is ... what? I tried putting in versions of "Folders('OR:wt.folder.SubFolder:xxx')"
  "Name": "",
  "IssuePriority": {
    "Value": ""
  "Requester": "",
  "State": {
    "Value": ""
  "TypeIcon": {
    "Path": ""
  "NeedDate": "2025-03-12T17:51:19.836Z",
  "@odata.type": "",
  "Context@odata.bind": "",
  "Folder@odata.bind": "",
  "Attachments@odata.bind": [
  "CIAffectLinks@odata.bind": [
  "AffectedObjects@odata.bind": [
 There are also:
"FolderLocation" and "FolderName"... both seem to do nothing to set the location.
If I want the created problem report to go to a specific folder, what is the correct syntax in the body of the API?
Fadel
23-Emerald I
(To:Dobi)
refere to https://www.ptc.com/en/support/article/CS429060 , there is a step to adjust the OIR too :
  • Sample Request Body:
  "Requester": "u1",
  "Category": {
    "Value": "COST_REDUCTION"
  "IssuePriority": {
    "Value": "LOW"
  "NeedDate": "2024-10-07T04:59:28.818Z",
  "Number": "PR002",
  "Description": "desc test",
  "Name": "PR002",
  "DescriptionSummary": "summary test",
  "@odata.type": "",
  "Context@odata.bind": "Containers('OR:wt.pdmlink.PDMLinkProduct:115304')",
  "Folder@odata.bind": "Folders('OR:wt.folder.SubFolder:665511')",
  • Comment out the following line from the Problem Report OIR when specifying the folder where the Problem Report is to be created.
  • <AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
    <Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
    <!--  <Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/> -->
    </AttrConstraint>
Fede
Fadel
23-Emerald I
(To:Dobi)
  "Requester": "u1",
  "Category": {
  "IssuePriority": {
    "Value": "LOW"
  "Number": "PR002",
  "Name": "PR002",
  "@odata.type": "",
    </AttrConstraint>
Fede
Dobi
17-Peridot
(To:Fadel)
I did ultimately have a tech support call and the thing that was missing from that support article was the OIR comment.
In my case, I didn't have the folder.id explicitly called out so there was no mechanism to set the folder with APIs. Once I added in the constraint (as you note above, commenting out the immutable portion), it worked as the support article suggests.
