We have a question if it is possible to allow an action for a numeric revision at a given state (In Work) but not allow the same action at alpha revision at the same state (In Work)?
The action is Delete.
You can probably create your own includeFilter. However there are 23 actions with name of delete (Windchill PDMLink 11.0 M020) so it might take a bit to figure out exactly which delete action you need to tweak. I would start with the one for type = object.
Keep in mind this will only hide the delete action. It will not change permissions (ie Policy Administration).
