Hello All,
I am looking for a way to provide the sequence to the Change Task through customization from the CN workflow. Is there any supported API which can be used to accomplish this?
Karan
WTChangeActivity2 task;
WTChangeOrder2 changeNotice;
String sequenceNumber = (String) wt.change2.changeplanning.ChangePlanningHelper.getService().getExecutionValues(changeNotice).get(task);
This will give you the sequence number of a given task and a given change notice.
I haven't figured out though how to modify those values. I can just read them and use the information in my workflow.
the below api can be used to create plan :
wt.change2.changeplanning.ChangePlanningHelper.getService().createPlan(VersionableChangeItem arg0, Map<String, WTCollection> arg1)
