I need to find a WTPart/WTPartMaster that matches to specific partNumber, partRevision, View and Organization I provide. How can this be achieved by QuerySpec? Or is there any alternative?
Hi @VM_13704617
I usually use joins to link the tables together and then I put the input criteria
here is an example how to use joins in the QuerySpec
Query spec for multiple objects
In your case you have to join following tables, WTPart, WTPartMaster, ViewReference,
PetrH
If you have a reference to the WTPart or WTPartMaster, you can use the VersionControlHelper service to get all versions then loop through those. A simple Queryspec would only need to get a part by number.
Hi @VM_13704617
PetrH
Hi @VM_13704617,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
