Reload WRS files without restarting Method Server?
Constantine
18-Opal
Version: Windchill 13.0
Use Case: Updating a custom WRS domain.
Description:
Hello All,
I need to do quite a lot of trial-and-error on my custom WRS domain, mainly manipulating .js files. Restarting MS every time to pick up my changes is annoying.
Since those scripts are interpreted by Nashorn anyway, I thought... maybe there's some magic trick (e.g. calling some MBean method) to reload them without restarting MS every time?
Thanks!
Vilia (my company) | GitHub | LinkedIn
Hi @Constantine
Thank you for your question.
Also, feel free to add any additional information you think might be relevant.
Best regards,
Catalina
PTC Community Moderator
PTC
At the end of the day I didn't find a good solution, so I fired up my Java debugger and moved the code from JS files into Java classes instead. This way I can do trial and error on my OData endpoints without restarting the server thanks to JVM code hot swapping. The latter has its own limitations, but it takes away 90% of the pain associated with restarting the MS.
Hi @Constantine
Its great to know what you have found some approach . I am interested to know  how did you achieved it in the java classes . can  you please elaborate about this JVM code hot swapping approach
