Rename action is disabled
Pushpak
9-Granite
Hi All,
With the same license and groups I can able to see Rename action in WC11 but In WC12 Rename action is disabled with same configuration anything needs to be done?
HelesicPetr
22-Sapphire I
(To:Pushpak)
Hi @Pushpak
Check the license group if there is not disabled profile with old license
Next try to .reset profile settings on the context
Very often after a upgrade to wch 12+ there is necessary to rearranged the licensees because some are not used anymore for example PDMLink license and so on...
PetrH
HelesicPetr
22-Sapphire I
(To:Pushpak)
Hi @Pushpak
PetrH
As Petr mentioned it sounds like a profile. You may want to check your profiles to make sure the rename action is visible
https://www.ptc.com/en/support/article/CS61251
https://support.ptc.com/help/windchill/r12.1.2.0/pt_BR/index.html#page/Windchill_Help_Center/profilemgmt/ProfileMgmtProfileEdit.html
I have encountered similar issues while upgrading to wc11.1 and wc12.0. Sometimes there is a funny issue with the std or license profiles that blocks or prevents access to actions. I have seen Set State, Rename and access to view the Supplier list in the past. For each item, I was able to work with PTC TS to get an updated profile XML to load that cured the issue.
Hi @HelesicPetr ,
This action is getting hidden. I can able to see in jcaDebug it is saying "Hidden by : Role Based Check"
Please find below attachment.
Thanks.
Pushpak
9-Granite
(To:Pushpak)
Hi @HelesicPetr ,
Could you please tell why it is hidden?
HelesicPetr
22-Sapphire I
(To:Pushpak)
Hi @Pushpak
Role base check is checking the license profile, if the action is enabled.
Usually specific check box is not checked for the action.
Check following article: CS362351
PetrH
