Two data utility for an attribute
DJ_10206604
can we have two Data Utility functions for the same attribute(datautility for making attribute multivalued and Picker datautiliy)?
HelesicPetr
(To:DJ_10206604)
Hi @DJ_10206604
I don't think so that you could mix two dataultity separately that way as you think..
You would need to find a way how to achieve what you need with multivalue attribute in one datautility.
That's just my thoughts
I've never tried it.
PetrH
Hi @DJ_10206604,
One attribute cannot be registered with two Datautilites.
Try to remove single valued constraint on attribute and register it with Datautility.
So, in that way it will be multi valued and picker.
Hope it works.
HelesicPetr
(To:TT_9345405)
Hi @TT_9345405
Good point to remove the constraint.
Additionally you need to process multivalued string in the data-utility.
The values are usually separated by "@" I guess.
PetrH
hi @TT_9345405  thank you for your response
we have already tried this approach of removing single valued constraint on type and attribute management and register the attribute with picker datautility
but it is not making the picker attribute as multi valued
is there any other way to make this picker attribute as multivalued ?
Hi @DJ_10206604
Instead of making a attribute multi valued.
we can set a property from the picker data utility itself where we can have multiple values set/shown in single textbox/combo box.
HelesicPetr
(To:TT_9345405)
Hi @TT_9345405
Good point
PetrH
