WT Part for service document
SG_10195899
I am creating service document library using Windchill classification explorer based on the attribute type & values. Our service documents are stored in MSword & PDF files and i believe it is unable to create classification explorer library using document attributes.
To avoid this issue i have created WT Part with same document attributes (Service doc is attached to related objects) and created classification library.
Is that correct approach? Do we have any other way to create library in Windchill? Can we create WT part for document objects, till now i have created only for CAD files, share your knowledge on this?
You can directly classify WTDocuments and this is likely the approach that you will want to use.
See for example CS309693 or Help at https://support.ptc.com/help/wnc/r12.0.0.0/en/#page/Windchill_Help_Center%2FWCClassAdminClassifyParts.html%23
The key is to assign the separate classification created for these documents to the WTDocument (or subtype of) object type, rather than a classification created for any type of WTPart.
Will need a separate classification binding attribute, namespace, classification structure.
Takes a bit to set up but works perfectly  🙂
Thank you Mike. i Can able to create document library.😇
Appreciates your response.
