What is the use of AvailableAttributes.xml file?
it is not always the case OOTB, and for sure custom modeled attributes need to be added Manually https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_UICust_PresentInfoUI_AddCustomModelAtt.html
Generally if we notice that an attribute is not available while creating/editing a a table view , we should look into that file .
PS other modules may have their own file i.e. MPMLink related table views setting is done in MPMLink-AvailableAttributes.xml
in that file you can define any additional attributes that need to be exposed to table views for a given type
https://www.ptc.com/en/support/article/CS194744 ,for example
