Windchill Authentication Alert and Selenium WebDriver
mluberti
I'm currently using Selenium WebDriver to automate testing for Windchill, and I'm running into a problem.  When the authentication window pops up, it pops up as an alert.  Since it pops up as an alert, I can't automate the input of the username and password.  There's no functions that allow for it.  Any tips on how to fix this?  I'm using Selenium 3, Java 8 and Firefox 45.
It's problem of selenium WebDriver.
I use TestNg + selenium(InternetExplorerDriver) + jautoitx(autoit in java)
Before driver.get(windchillBaseUrl) run Thread WindowLogin wait for arlet (Login) set username, set password and push Enter. Wait for load home page then go tests.
ddhini
(To:mluberti)
Simple,
Sent username and Password along with WindChill URL. I have done a similar kind of things in my past.
If you cannot get in the above method then Set UserName and Password in a Local Credential Manager Temporarily. It will directly land you inside the WindChill site whenever you navigate to Windchill Site in browser
Kind Regards,
Dinesh
