WizardStep Not Closing After Validator DENIED
福耿_13361195
Version: Windchill 12.1
Use Case: Open a Windchill folder and click 【Export List to CSV】.
The exportTable.jsp wizard opens with a wizardStep
Add a custom validator before the standard export processing:
return UIValidationResult.newInstance(var1, UIValidationStatus.DENIED, UIValidationFeedbackMsg.newInstance( "Error message", FeedbackType.ERROR));
The validation message displays correctly in the wizardStep popup.
Click OK on the message dialog.
Expected Result: After acknowledging the validation message, the wizardStep popup should close safely without JavaScript errors.
Description:
When adding a custom validator to Windchill’s standard “Export List to CSV” action,
the validation message displays correctly in the wizardStep popup.
However, after clicking OK in the message dialog,
the wizard does not close properly. The browser console logs the following JavaScript error
windchill-all.js:1556 Uncaught TypeError: top.finishServerSideExport is not a function
    at PTC.exportTable.exportTableSuccessListener (windchill-all.js:1556:281)
    at handleSubmitResult (windchill-all.js:3759:62)
    at handleSubmitResult (windchill-all.js:2317:91)
    at ext-and-extensions.js:1845:156
Hi @福耿_13361195
Thank you for your question.
Also, feel free to add any additional information you think might be relevant.
Best regards,
Catalina
PTC Community Moderator
PTC
Hello @福耿_13361195
In my opinion this is standard behavior, if there is an error after you click the OK.
The error message informs a user that there is something wrong there and user has a option to correct the wizard input.
So there for the wizard is not closed.
If you need to change this behavior, you have to add a FormResult - setNextAction or find a way how to do so in wch 13.1+ because some methods are deprecated
PetrH
