to execute jasper report from input jsp page I am using the following API-
ReportHelper.manager.getThirdPartyReportExecuteUrl(reportRef,parameters);
Here, the reportRef should be of type ObjectReference and should refer to a Windchill report object. However the object that I get from the jsp page using the request.getParameter("oid") is of type WTDocument.
Now, when I try to send this object in the above API , it gives the error-
java.lang.ClassCastException: class wt.doc.WTDocument cannot be cast to class com.ptc.windchill.enterprise.report.Report (wt.doc.WTDocument and com.ptc.windchill.enterprise.report.Report are in unnamed module of loader 'app')
Kindly suggest on how to resolve this.
Ramsha
Hi @RK_10805837
You should search for the report.
How do you define the reportRef and parameters?
The WTDocument object is not report template that can be run as a report...
The ObjectReference should give you com.ptc.windchill.enterprise.report.Report
PetrH
