when i want to edit the workflow template ,it can't display
windchill version:windchill 10
java:java6
Are you able to view the workflow template? If you are not, then I guess there is java applet issue You can downgrade your java version to 1.7 update 65. It works fine on my system.
Hope this helps.
Sitanshu
Thanks! I'll try!
