Hi all:
In the original solution in Integrity 10, I copied input document type with its input/share input types to create a new document type, also I adjust the new document type's document model configurations in the Edit Type dialog, but it can not be displayed in the document menu of the client UI when I want to create a document with the new created type, why?
I run into the same problem when I'm testing document issues myself. The usual cause is that I have not set state transitions for the new document. Make sure you have at least one of these set in the workflow section of the edit document screen, and also make sure that the transition itself has its permissions set accordingly.
Did this solve your issue?
