I'm searching a possibility to transfer an MS Excel table fragment automatically via Integrity im-command into a Text-Field (Attribute) of an Integrity Workflow & Document item. Currently I'm trying to get a solution using the MS Windows-Clipboard, that means as first step copying automatically the MS Excel table fragment into the MS Windows-Clipboard. For the second step I need an im-command or other possibility to transfer the content of the MS Windows-Clipboard automatically to the destination (Text-Field of a PTC Integrity Workflow & Document item).
Is there any possibility to fix this issue, maybe also via a different solution?
Additional I'm interested in a possibility to transfer formatted text (for instance bold text or specific font) into a Text-Field (Attribute) of an Integrity Workflow & Document item.
Best Regards
Stephan
