Hello Support,
in the CLI si viewproject --project="#p=/root_project/project.pj#s=sub-project/project.pj#d=dev_test" how do I provide the sub-project revision number on the development path dev_test?
--projectRevision= is not allowed because --project= option is being used.
Eagerly waiting.
Thank you.
Hello Pashan,
Then I don't understand the question because my example works and it does use projectRevision with the project option.
I have never seen this syntax in the CLI: "#p=/root_project/project.pj#s=sub-project/project.pj#d=dev_test", so I may be confused.
Have you tried the syntax I proposed, especially example #2?
If you want a specific checkpoint (project revision), you don't have to specify the devpath since it's already implied.
Sorry, that's all I have.
I think you want the "--devpath" option.
From the example you provided, the command would be:
si viewproject --project="/root_project/sub-project/project.pj" --devpath=dev_test
You could also try:
si viewproject --project="/root_project/sub-project/project.pj" --projectRevision=1.3.1.5
In this example, your dev path started from main line checkpoint 1.3 and has a number of checkpoints
Notes:
- The two commands are not strictly equivalent depending on context, but I include them because you did mention projectRevision.
- No need for "#", and there is no distinction between project and sub-project in this case.
- You can type "si viewproject -?" for syntax and all options (true of any command).
Hello Laurent,
That will not work, because when you use --project= option then --projectRevision= will not be accepted. That's what my question was. When I use --project= option, then how do I mention the version number in the CLI for "si viewproject" command.
Hopefully my question is clear.
Thank you.
Hello Pashan,
Hello Laurent,
You are right. It works as you mentioned.
Thank you.
