Can MS SQL 2019 be used with Windchill RV&S version 12.5 ?
LLawton
I'm upgrading our Integrity version 11.2 to the latest, but I have to go to Windchill RV&S version 12.5 first.
We currently use MS SQL Server 2008, and if I follow he documentation, I should go to SQL 2016 first, then upgrade to SQL 2019 for the next upgrade.
Our DBAs say we could go to 2019 directly.
Has anyone run Windchill  RV&S 12.5 on MS SQL 2019, or are there reasons not to do it?
Thanks.
KartikOak
(To:LLawton)
     Do take note that if you are coming from 11.2 to 12.5 with an intention to stay on it for a long time - the patch support ends in June 2023.
Kartik
