How can we capture a event (i.e Delete , Insert, Copy etc).
So that we can use that event in a trigger rule.
For Example ( What I want to do is:
If user want to delete( right click to delete ) a content of a Segment and then change the project of deleted content to xyz project.
How can I capture the delete event, so I use that deleted event in trigger rule to change the project.
Please guide us.
Its urgent if anyone can guide me on phone then pls share your number. I will call.
