Compile related object when promoting Copy Books
ptc-4670881
Is it possible to configure Implementer to automatically compile members that use an RPG Copybook (/copy or /include) compiler directive? Currently when we promote a source member that is a RPGCPY code/type and specify Include Related Objects it does not include/recompile those members that have the member on a /copy or /include statement.
David_G
(To:ptc-4670881)
Copy books as related objects support was added to Implementer quite a while ago.
Have you run a BMOL over the environment that the copy books and their related objects are in?
If not, use the IBLDMBOLST command with OBJTYPE(*REL) to rebuild the related object relationships.
david
IBM i on Power Systems: For when you can't afford to be out of business! I'm riding in the American Diabetes Association's Tour de Cure to raise money for diabetes research, education, advocacy, and awareness. You can make a tax deductible donation to my ride by visiting https://ptc.diabetessucks.net. You can see where my donations come from by visiting my interactive donation map ... https://ptc.diabetessucks.net/map (it's a geeky thing).
