Hello All,
I am using PTC RV&S 13.2 and sometimes the tool gives me option to delete large sum of data and sometimes not.
My use case is after i branch a requirement document, i filter the requirements that i do not want in the new branched document. After applying the appropriate filter, i select all items and see that the delete option is disabled.
I am able to delete one requirement at a time. but it is not efficient when there are more than 100 to 500 line items.
Under view -> option->editng-> operations mode : i have tried selecting all the 3 modes and still sometimes i get the delete option and sometimes not.
Are there any nodes that are in a non-editable state?
Depending on the settings, the category can also be a problem. Sometimes it is not possible to delete several nodes if there is a "description" underneath them.
When there are about a 100 line items, is there a way to see what is editable and what is not ?
how can i see this ?
This is difficult to say from a distance, as it depends on a number of factors and we do not know your solution.
For example, does your solution have one or more node states in which the node is read-only? Then you could filter for that.
Have you referred to the documentation around this topic - you can find it here.
If you still see the discrepancy you have referred to, please file a support case.
Kartik
The content you have shared is very generic.
The issue is that the delete option under content is disabled.
I want to know under what conditions can this be enabled and how can i work on my use case of deleting multiple selection of requirements in a document.
Vishwas
