Determine development path of a build-subproject using CLI
mrömmele
I need to determine the development path of a subproject that is currently configured as build. I already tried "si viewprojecthistory --rfilter=branch::current" to only focus on the current branch. When doing this in GUI, also "Development Path" and "Checkpoint Description" are being displayed for each checkpoint. But using the respective command in CLI, these fields are not being reported. Can I request this information using another si-command?
0 REPLIES 0
