Dear Community,
We are looking for an option to extract the data out of PTC Integrity 10.8 and store into a validated archive location (or tool) as per compliance requirements.
In our company we are using PTC Integrity 10.8 for Change Management purposes and will need to migrate the data out as we moved to another solution to document our Change Controls.
Note about product: Windchill RV&S (formerly Integrity Lifecycle Manager)/ Release 10.8
We would need to extract the Change Control records, their history, attachments and approvals.
Currently we are in Sustained Support mode and cannot get any assistance from PTC beside going through documentation, KB or Community.
Hope that someone has experience with similar activity or can at least suggest a starting point to investigate our options further.
Some possibilities that we have on our mind:
- export record by record through UI using a bot
- using CLI to export record details, history, attachments, approvals
- integrate the product with an Archive or BI Tool via available API
Looking forward to hear any ideas.
Thank you in advance.
Kind regards,
Antonio
We are now in the exact same boat as you. Did you ever figure it out? If so do you mind sharing the details please?
