Hi to all
Currently, in order to fill a SI Project field, it takes quite some time to navigate to the correct subfolder and select the relevant checkpoint/snapshot.
In my opinion, it would be beneficial if it could also be done via drag & drop from the Project History View.
Have a nice day!!
Hi Ramona Schiller,
These sound like a enhancement requests, which get captured in the Ideas section. To get there, you can click on Discussions up above, then on Ideas.
Kael
