Gateway : Parser for reading Table content from the Word Document
vbabu-4
Recently we have configured gateway to import content of document into Integrity. It workd perfect as expected. But our requirement is to import content of the table in to Integrity i.e each column should import to the specific field available in Integrity.
So kindly guide me with same xslt to read the content of the table into Integrity fields.
Thanks for your support.
VSB
with table data you mean a Word Table inside a document?
Is the Word document only one large table?
Does it contain images and formatted text, bullet points, embedded objects?
(I am not aware of any XSLT definition file yet, but your use case sounds interesting to me)
