I would like to know if there is a command that returns the name of the Integrity user who created a label attached to a member in Source Integrity. Using "si viewlabels member" i only get the names of the labels and the member-revision they are attached to. Is there a way to get more information about a specific label?
Thanks!
Stephan Knopp
Hi Stephan,
Audit logging if enabled and setup on the Integrity server, could aid you in looking this info up, but of course, you would have to have that setup already. Audit logging is covered in the Integrity Administration guide. You can enable various Configuration Management actions to capture in audit logging, but "addLabel" is one of them.
Hello Stephan Knopp,
CS133798: How to enable or disable Audit Logging in Integrity would probably also be helpful for you, as would CS144302: How to configure Integrity Audit Logging to track member and project changes.
Kael
I wanted to get this information inside a trigger script, so using the log won't work, but thanks!
In that case, you'll need to file a feature request with PTC Integrity Support. Please refer to this thread in the request to provide additional context.
Kael
