Example: "ALM_Defined" state ALM_OPEN POINT is created by the end-user. I want to automate the workflow process using standard procedure with CLI Batch script as follows.
STEP-1: Edit the ALM_OP, add conclusion and change state to "ALM_Checked State"
STEP-2: Create relate item (ALM_Change Request) for the Checked state "ALM_OP"
STEP-3: Edit the "ALM_Change Request" and prompt to Initiated, Defined, Checked, Analysed states.
STEP-4: Create relate item (ALM_Task) for the Analysed state ALM_Change Request.
Hello vijayakumar s,
For the corresponding steps with the minimal arguments I can interpret from your request:
Kael
Kael
