Is there is any way to auto sync the sandbox from a specific location?
Shankar
I suggest to use a windows script on a scheduled base, using the CLI command "si resync".
With the parameters of that command you should be able to sync the data you need.
Greetings,
Klaus
Hello Shankar,
I'm trying to imagine what you mean by auto-sync. I'm guessing your use case involves the latest members of the mainline or a devpath updating automatically triggering a sandbox to do a refresh. Is that what you are trying to do?
This could probably be done with a trigger script running off of configuration management events, but would likely involve writing your own custom trigger script to do so, or getting a Global Services engagement to write such a trigger script for you.
Kael
Greetings,
Klaus
