How to check for updates to the Implementer Plug-in for IBM Rational Developer for i?
rberendt
When in IBM Rational Developer for i I do a Help, About, and see I am at Version: 7.1.0.75 of the Implementer Plug-in. How do I check for updates?
David_G
(To:rberendt)
The Implementer plug-in for Rational Developer is just a regular Eclipse plug-in ... so you would use the built-in plug-in update procedure.
Do the following:
  • Click on the Help menu
  • Select Install New Software... (you could use the Check for Updates, but I find the Install New Software option faster).
  • When the Available Software dialog is displayed, select the software site that you setup for the Implementer plug-in.
  • If there is a new version of the plug-in available, it will be shown.
NOTES:
  1. The Implementer plug-in is tied directly to the version of Implementer being used ... if there is a new version available the plug-in will require an update in order to function.
  2. The Implementer plug-in does not rev very often. Usually only on a new Implementer version install/upgrade. Chances of an update being required is fairly slim.
IBM i on Power Systems: For when you can't afford to be out of business! I'm riding in the American Diabetes Association's Tour de Cure to raise money for diabetes research, education, advocacy, and awareness. You can make a tax deductible donation to my ride by visiting https://ptc.diabetessucks.net. You can see where my donations come from by visiting my interactive donation map ... https://ptc.diabetessucks.net/map (it's a geeky thing).
rberendt
(To:David_G)
Thank you for your reply.
Is there a chart listing Implementer level compatibility with Plug-in? Like "Version . . . : 11.0" of Implementer goes with 7.1.0.75 of the Implementer Plug-in?
David_G
(To:rberendt)
The plug-in version always is in sync with the major build id of Implementer.
Use the IDSPVER command to determine the build id ... the major build id is 7.2. The plug-in will be version 7.2.0.75.
If there is a new plug-in released for a specific Implementer release, the 3rd segment of the plug-in version will be incremented.
The last segment of the plug-in version indicates if it is used for RDi 7.5 and higher or not. The plug-in used for WDSC 7.0 and RDi 7.1 does not have the .75 at the end. (We have deprecated support for WDSC 7.0 and RDi 7.1).
rberendt
(To:David_G)
IDSPVER indicates
Implementer 11.0 (build 7.1 140429)
so 7.1.0.75 matches "7.1 140429" because of the 7.1 alone, right?
David_G
(To:rberendt)
Exactly right, Rob.
