Is it possible to delete (or brake) the branch Information between documents?
For example I have document A and create a branch document B.
Now I have the Information in document B, that document A is the root document.
How can I delete the root document Information in document B?
I've tried to change the reuse property but that's not exactly what I am looking for.
Sometimes it is a bit confusing if I run a document report and see the branch or the root document.
Thank you very much for your help!
Florian
to break the branch, you will need to toggle the item from Shared to Reuse and edit one of the "Significant Edit Fields" of that item type
Take a look at the following: (Branching Documents (ptc.com))
This may be the answer (which you did not want...).
