How to develop a java plugin for checkout operation with integrity
vk
I am developing a Java plugin using plugins provided by integrity to communicate with Integrity.
I am able to connect to the server. I need some inputs regarding checkout process.
I got the below code when I searched. But I am not sure what parameters do I need to pass for this method.
configPath is either sandbox path or servers path?And please check the parameters mentioned whether I am giving the correct values or not?
And In my code I am using first argument as Session instead of APISession.
When Iam running it it is giving me the error Error occurred when running command: si: MKS124819: Invalid option: "server"”.
What are all the option values it accepts? Is it different for every command? Where can I found this information?
Please suggest me If i can develop in a different way also.
        * Performs a checkout of this Integrity Source File to a  working file location on the build server represented by targetFile
        * @param api Integrity API Session
        * @param configPath Full server side path for this Integrity member's project/subproject
        * @param memberID Full server side path for this Integrity member
        * @param memberRev Member revision string for this Integrity member
        * @param targetFile File object representing the target location for this file
        * @param restoreTimestamp Toggles whether or not the original timestamp should be used
        * @param lineTerminator Sets the line terminator for this file (native, crlf, or lf)
        * @return true if the operation succeeded or false if failed
        * @throws APIException
       String configPath="mentioned server side path till .pj";
       File targetFile=new File("D:/Vasavi/test-generated ");
       String memberID="config.ini";
       String memberRev="1.10";
       boolean restoreTimestamp=false;
       String lineTerminator="native";
       Response res;
       public boolean checkout(APISession api,String configPath,String memberID,String memberRev,File targetFile,boolean restoreTimestamp,String                lineTerminator) throws APIException {
              System.out.println("In Checkout method");
            if (!targetFile.getParentFile().isDirectory()) {
              System.out.println("If block");
           targetFile.getParentFile().mkdirs();
           System.out.println("end of if block");
       System.out.println("after if block");
         Command coCMD=new Command(Command.SI,"co");
         coCMD.addOption(new Option("nolock"));
         coCMD.addOption(new Option("server",configPath));
         coCMD.addOption(new FileOption("targetFile",targetFile));
         coCMD.addOption(new Option(restoreTimestamp ? "restoreTimestamp" : "norestoreTimestamp"));
         coCMD.addOption(new Option("lineTerminator",lineTerminator));
         coCMD.addOption(new Option("revision",memberRev));
         coCMD.addOption(new Option("changePackageId", ":none"));
         coCMD.addSelection(memberID);
         try{
         res=integrity.cr.execute(coCMD);
catch (APIException e) {
System.out.println("Error occurred when running command: " + e.getMessage());
e.printStackTrace();
         if (res.getExitCode() == 0) {
           return true;
        else {
           return false;
vk
(To:vk)
Instead of "project" option, I mentioned it as server.
mrump
(To:vk)
you have to differenciate between two use cases:
1. a checkout (API command = si co) always requires a given sandbox, that defines the working location for the now editable member.
2 (and I assume that is your case) a fetch/download of a single member into a arbitrary location (API command = si projectco).
Please read up the details in the CLI reference document. (e.g. for I10.6 = http://support.ptc.com/WCMS/files/163511/en/SourceCLIReference_Integrity_10_6.pdf)
As a start for your development, here's a snippet from the Jenkins Plugin's source code on GitHub https://github.com/jenkinsci/integrity-plugin/blob/master/src/main/java/hudson/scm/IntegrityCMMember.java
* Performs a checkout of a Integrity Source File to a
* working file location on the build server represented by targetFile
public static final boolean checkout(APISession api, String configPath, String memberID, String memberRev, Timestamp memberTimestamp,
      File targetFile, boolean restoreTimestamp, String lineTerminator) throws APIException
// Make sure the directory is created
if( ! targetFile.getParentFile().isDirectory() )
// Construct the project check-co command
Command coCMD = new Command(Command.SI, "projectco");
coCMD.addOption(new Option("overwriteExisting"));
coCMD.addOption(new Option("project", configPath));
coCMD.addOption(new FileOption("targetFile", targetFile));
coCMD.addOption(new Option("lineTerminator", lineTerminator));
coCMD.addOption(new Option("revision", memberRev));
// Add the member selection
// Execute the checkout command
Response res = api.runCommand(coCMD);
LOGGER.fine("Command: " + res.getCommandString() + " completed with exit code " + res.getExitCode());
// Return true if we were successful
if( res.getExitCode() == 0 )
  // Per JENKINS-13765 - providing a workaround due to API bug
  // Update the timestamp for the file, if appropriate
  if( restoreTimestamp )
   targetFile.setLastModified(memberTimestamp.getTime());
  return true;
// Otherwise return false...
else
  return false;
