How to make Integrity field labels take on a "mandatory" style through aTrigger
Zeiad-Alkassem
How i cann  make Integrity field labels take on a "mandatory" style through aTrigger under certain conditions  or Field value?
Hello Zeiad Alkassem‌,
I don't think you can do this solely through a trigger, but you can do it in conjunction with another field (e.g. a logical field).  You'll probably find CS129992 and CS139416 to be helpful.  You can then use a trigger to set the field if it's appropriate, or possibly use a field computation instead of a trigger.
Kael
Kind Regards,
Kael Lizak
Hello Kael,
Thank you for replay , i had already used with certain Logical value. i think it's good if i can do it through a Trigger.
Zeiad
