How to open a URL using Trigger?
ptc-4672719
Currently I've a requriement, whenever a defect or item is created I need to open one url via trigger. Let me know what is the code to open an URL via trigger?
Thanks & Regards,
shankar
9 REPLIES 9
Do you want to open up the Integrity web client to a specific item/object or do you want to open a browser to an external website?
I want to open a external website(JIRA URL)
Anyone know how to open a URL from a remote machine?
Shankar
khoppe
(To:ptc-4672719)
Is it a fixed URL or a dynamic URL, depending on infos from out of the item itself?
Greetings,
Klaus
mrump
(To:ptc-4672719)
Hi Shankar,
I'm looking for a similar solution in a different use-case.
I would like to trigger my build server (Jenkins) when checkpoint is created in Integrity (and the project meed some special conditions).
So basically I need a way to KICK-OFF the "run build URL" on my Jenkins from inside my Integrity java script source trigger.
Of course the trigger must be non blocking.
Did you find a solution so far?
Regards Matthias
Hi Matthias,
I can provide a solution for your use case (we have the same use case):
var eb = bsf.lookupBean("siEnvironmentBean");
var pb = eb.createProcessBuilderBean();
pb.setCommand("wget -q --spider --no-check-certificate --http-user=xxx --http-password=yyy https://zzz);
pb.start();
Regards, Ingo
mrump
(To:imontermann)
Thanx Ingo, you just saved my day
KaelLizak
(To:imontermann)
Shankar,
What was it about this answer that did not resolve your request? Maybe we can tailor it to meet your needs?
Kael
Kind Regards,
Kael Lizak
mrump
(To:imontermann)
Here's an alternative for those users on Windows Servers that do/can not want to use "wget".
It's the same command in PowerShell and works just great for us:
pb.setCommand("powershell.exe -command \"$client = new-object System.Net.WebClient;$client.Credentials = New-Object System.Net.Networkcredential('xxx','yyy');$client.DownloadFile('"https://zzz/"' , 'c:\\temp\down.html' ); \" ");
pb.start();
HTH Matthias
