I try to import a *.reqifz file with PTC Integrity Requirements Connector 3.1 but this operations has no successful.
I attach the report that include the error message:
Property | Value |
Result | Error |
File format | ReqIF 1.1 |
Type | Import |
Date | Wed Nov 16 10:58:22 CET 2016 |
Tool name | PTC Integrity |
Tool version(s) | |
Executor | Alessandro Il Grande |
Comment | |
Execution time | 00:00:00 s |
Document path | Document name | Document ID | Operation result | Object count | Changes | Operation time |
/projects/Prova | Prova | Error | 0 | - | 00:00:00 s |
Severity | Message |
Error | Import failed with exception 'java.lang.NullPointerException'. |
I don't have any idea to solve my problem. Do you have any suggestions?
Hallo Alessandro,
i suggest that you open a case with PTC Support,
Hello Alessandro Il Grande,
Did you contact Support? Did they provide a solution? Is it something you could share with us?
Kind Regards,
Kael
