MKS124814: Cannot show view information: The source trace fields must be specified
amatei
In the Integrity Workflow and Documents I do these steps
1) Open a requirement
2) Select a source trace field to a member and select Item > Source Link > Source Trace Viewer.
3) I get the following error: MKS124814: Cannot show view information: The source trace fields must be specified
See attached file please
LLawton
(To:amatei)
From the screenshot, I have a feeling that your Link to Source field is a source link and not a source trace.
Therefore the source trace viewer doesn't know what to do and you get the error.
Try to double-click on the file listed in the field instead of using menu options. Then see where that takes you.
If you have admin rights, you can also look at the definition of the field to confirm its type.
Let us know what happens please.
amatei
(To:LLawton)
Hello
Double-click opens the revision 1.1.1.1 in the Member History (in Configuration Management)
See attachment
Where exactly should I look to see the field definition?
LLawton
(To:amatei)
For the field definition, in the Values tab there should be a checkbox with the name "Trace" and it should be checked to indicate that it is a source trace field.
LLawton
(To:LLawton)
I take it back...
I just experimented on my system and if the item does not have a value in a source trace field, then the menu item is disabled (greyed out).
So your field must be a valid trace field and something else is happening.
You should open a ticket with PTC Support.
MichaelChatel
20-Turquoise
(To:amatei)
I agree with LLawton - opening a Support case with Integrity support is probably your best bet here.
I suspect you may be running into a defect.
We are using Integrity 11.0.0.506 with service packs up to C160000000-037
I also verified these links, but it didn't help
http://www.ptc.com/en/support/article/cs111447
http://www.ptc.com/pt/support/article/cs164533
