Please point me in the direction of documentation for an explanation of messages VIM1717 and VIM1735 and how to resolve them.
mkeyter
This is the section dedicated on how PTC eSupport Help works.
You have to ask in the right section if you want some help from community users.
Please reply to this comment, adding for which PTC SW you are asking help and Toby will move this discussion for you.
Marco
The question relates to PTC Implementer version 12.
Please log cases in the eSupport web site. This is meant to be a discussion vehicle between customers and not a means to contact Support. We do not view this website as frequently or quickly as we would a logged support case.
Welcome Mike.
Thank you Marco Tosin‌ - moving this to Integrity.
Best,
Toby
We can work on this in the case I created - 13313094.
KaelLizak
(To:smigliorato)
Hello Mike Keyter‌,
It looks like Sharon Migliorato‌ helped you resolve this, and the solution in CS166883: How to identify why object code not found for object in Implementer repository build process.
Kind Regards,
Kael
Kind Regards,
Kael Lizak
