we used Integrity-Command „si rlog“ with different options to export the highest revision of each project member,
complete used command line stated below. This export worked fine with Integrity 10.3.
Now we moved to Integrity 10.8 and recognized problems with the export, because the result of the export contains
only the initial revision of each project member. We are using exactly the same command line stated below.
It seems that Integrity 10.8 is not able to handle the option “—revision=:head”.
Any idea or solution for this Problem ?
Best Regards
Stephan Klemm
Used command line:
si rlog --user=<user id> --hostname=integrity --password=<password> --project=/example/project.pj --format="{attributes};{relativemembername};{author};Rev {revision};{date};{state};{projectname};{alllabels};{archivename};\"{description}\"\r" --noHeaderFormat --noTrailerFormat --revision=:head --recurse --batch --Yes
Hi Stephan,
I suggest opening up a Support case with the Integrity support team, as this seems like a defect if it was working before in 10.3. I'm aware of a couple of defect SPRs in relation to rlog, and some of the symbolic revision filters, so that could be at play here.
Example, this is one I'm aware of, that seems like it could be related.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS222352&lang=en_US
Open up a Support case, and they should be able to help identify why you are seeing this, and if it is a defect, as I suspect, they will make sure you are linked up with the appropriate defect.
