Using RV&S Windchill JAVA API in Linux environment (integrity)
JK_10191180
I would like to ask if the JAVA API provided by winchill system can be used for application in Linux (Ubuntu, Rocky OS) environment. I know that winchill JAVA API is operating successfully in windows OS(RV&S already installed in PC).
Any ideas or advice if there is any way to use Integrity (Winchill RV&S) API in Linux environments, even if it is complicated.
Thanks.
- jw Kwon.
Hello JK_10191180,
I am not sure if this will help.
Did you check our platform support page & resources available online?
Community Moderation Team.
