Using SMP and Implementer
pmiller-3
Has any  anyone added SMP (Symmetric Multi Processing)   to their ISeries and ran SMP during remote promotions that included both SQL table and Index recreations , with PF and LF changes?  I am looking for both positive and negative results.
David_G
5-Regular Member
(To:pmiller-3)
Have you encountered a problem with SMP enabled during a promotion?
I wouldn't expect there to be any problems... IBM i will handle all the technical intricacies under the covers.
Implementer uses standard interfaces when promoting database objects.  SQL commands (ALTER TABLE, CREATE INDEX, etc) for SQL objects and CHGPF / CHGLF for PF's & LF's.
david
IBM i on Power Systems: For when you can't afford to be out of business! I'm riding in the American Diabetes Association's Tour de Cure to raise money for diabetes research, education, advocacy, and awareness. You can make a tax deductible donation to my ride by visiting https://ptc.diabetessucks.net. You can see where my donations come from by visiting my interactive donation map ... https://ptc.diabetessucks.net/map (it's a geeky thing).
Paul,
Was David's answer helpful?  If not, could you let us know what you feel is missing from the answer, or why the results weren't satisfactory?  If it is, could you press the Correct Answer button on his post to let everyone know the solution to this problem?
I would press the button for Correct Answer,  if it existed  on my page, (No Actions are available).
