Hi all,
in SI ("Configuration Management") you can see in the project view in the column "member revision" the revision number of the members contained in a project. In the helpfile (http://<servername>:<port>/integrity110_hc/index.jspx?id=client_proj_opening_projects.mif-2&action=show) you can read that this column also shows the revision of contained subprojects:
But this is not the case in our system (ILM 11.0.506):
As you can see in the project history, the selected subproject has revisions up to 1.12, but in the column is nothing to see.
I also don't remember that this would have been the case in previous versions of Integrity. I'm asking here if anyone else sees the revision of a subproject in the project view and we have a misconfiguration somewhere in our system?
Thanks, Jens
I already was afraid of that, but sometimes I'm not sure if what I'm looking for hasn't been seen somewhere before.
kind regards, Jens
I guess you might have seen that in a build sandbox
or a build project view.
Projects and sub projects do not have a revision but a "current state", unless
a special build resp. checkpoint is referenced.
I guess this is meant with "(if any)" in the documentation.
HTH
Jürgen
Hi Jürgen,
yes, i've seen these numbers in build sandboxes, but i was confused by the sentence in the documentation and i wasn't sure anymore, if i had seen this ever before in normal sandboxes or in the project view.
kind regards, Jens
