I recently did an installation of Integirty 10.8 on RHEL VM. I followed the documentation along and the installer said it has successfully installed the server but for some reason I'm missing the mksis file to start the service. Has anyone had this issue before? Is there a way to get this mksis file?
I've seen this before when the linux installation failed (usually a silent install). Could that have happened here?
You'll need to check the install log file (i.e. Integrity_Server_10_Install_[datetime].log in the install directory) because the silent install can fail silently and not return the right error code.
The mksis file is updated after the db install - look for the following lines. If the log file ends before these lines, then the installation didn't work correctly.
Custom Action: mks.install.is.RunDBInstall
Status: SUCCESSFUL
Custom Action: mks.install.is.Policies
Status: SUCCESSFUL
Modify Text File - Multiple Files: bin
Status: SUCCESSFUL
Status: SUCCESSFUL
I did check the install log and saw that everything was successful except this line
Modify Text File - Single File: /pdm/ptc/plmadm/integrity10.8/bin/mksis
Status: ERROR
Additional Notes: ERROR - Unable to locate ASCII text file to be manipulated. Deferring...
Also this was not a silent install, used the graphic installer for the installation.
