properties file history changes is missing
jsummers
11-Garnet
It would be an asset if we had the ability to see the properties files history of changes in a log or like other changes made with in Integrity Types.
The history would include the properties name, before and after values, date time stamp and user id that made the change(s)
Such as the properties.is properties file.
ssaul
(To:jsummers)
We use Integrity Source itself to track changes on config files, scripts etc. (Version control on all config files)
Would this be a workaround / possible solution?
jsummers
11-Garnet
(To:ssaul)
I'll have to give that a shot
