Windchill PLM "Creo View" Tips & Techniques Session Recording (West Coast)
No ratings
Check out this video on Using Creo View in Windchill from PTC Application Engineers
Presenters: Ryan Butcher (Technical Specialist, Fellow) and Jason Petersen (Technical Specialist, Principal)
Original Date Presented: September 7, 2021
To dive deeper into the subject, check out Windchill Creo View - PTC University.
Comments
Webcast Q&A
Question from BruceCan an annotation set, somehow be transformed to a Simplified Rep to Creo?
Answer:  What you do inside of Creo View does not go back to Creo Parametric.  But you could bring a Sim Rep from Creo into Creo View.
Question from BruceCan Creo View annotation be exported as a STEP file?
Answer:  No.  However, someone can download Creo View Express which is free and then they would open the PVZ which has the annotation in it.
Webcast Q&A
Question from JPIs there any Compare in Lite?
Answer:  No, when you have Creo View Lite, only the Design Check Review and Augmented Reality will be available on the Tools tab.
Webcast Q&A
Question from MikeIf you have your own A/R server, how is it configured in Creo View to export to that server rather than to the ptc.com server?
Answer:  The Publish in Creo View is only to the PTC cloud instance.
Webcast Q&A
Question from MichaelDo you need any other AR licenses (like Vuforia Studio) to use the AR feature of Creo View?
Answer:  No, you do not need a Vuforia Studio license.
Webcast Q&A
Question from PatrickCan you compare something that was just 2D to something that is now 3D with 2D associated drawing?  For example a lot of data might be legacy that had a 2D master with only a pdf.  Can I compare that pdf with the pdf comparator?
Answer:  You would compare the original 2D drawing to the update 2D drawing, not 2D to 3D.
Webcast Q&A
Question from RaghuHow would I display the AXES created in Creo Parametric and cut a section through one of them?
Answer:  You would turn on Datum Axis to be included in your Recipe setting for publishing out of Creo View.  Then you need to turn them on in Creo View to be referenced.  I.E. RMB in your view / View Settings / Filters / Check Axis On.
Hi @RyanL.Butcher
We have a case where production planners open a number of viewables into the same current session of Creo View. This is done to assist with work packages in the context of the overall design. What we find is we cannot then remove / delete the viewable or close from current session. Is there a way to build a temporary structure that can be manipulated using viewables direct from Windchill.
Dave.
‎Sep 20, 2021 12:09 PM
