Accessing windchill reports by standalone application
vk-3
We are working on developing standalone application, which requires data from windchill.
We  already created required reports. For some reason, we need to access those reports from outside windchill app from client machine.
Also I am open to any language either C# or Java.
We have windchill 10.x environment.
Thanks in Advance.
Vinoth
BineshKumar1
(To:vk-3)
I think the best approach is to write an info*engine webject and call it from your application. Again it depends on what sort of data are you trying to fetch from Windchill.
You can get a good example of this from https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS167152
Thank you
Binesh Kumar
Barry Wehmiller
Binesh Kumar‌ Thank you for the reply.
We have restriction of not modifying anything other than the Report management Utility.
I would like to fetch Single level BOM structure and list of linked documents in "Described by Documents" section.
Vinoth
