Testing the OOTB Change Request I set up a test product using the general product template. I then created a number of parts. Switching to the Team minor tab I added my user and my test user accounts to each of the roles with the exception of guest and Members which I left empty.
I then selected New Change Request on one of the parts. After completing the Wizard and submiting the change request my two accounts assigned to the Change Admin I role received the Analyze CR email as expected. The problem is that so did all of the administrators.
When I openned the assignement with one of my accounts I found both of my accounts and Administrators listed under the assignment
I've double checked the team assignments and looked under organization and site trying to find out why the Administrators are receiving the Analyze CR notification. Any ideas on why Administrators are getting the Change Admin I role?
Thanks in advance
-Chris
I am experiencing this exact symptom with Change Requests as Chris points out below. I am running 9.1 m062. Has anyone figured out why the Admin are receiving the assignment even though they are not in the Change Admin 1 role?
Curiouser and Curiouser
In Reply to Chris Lindberg:
Thanks in advance
-Chris
Thanks in advanceto all you wicked smarties out there,
Bob Lohbauer
