I've installed the Adobe Experience Manager (AEM) 6.3 using the turn-key installation. What I need to do now is run the admin UI over https using a certificate signed by our Certificate Authority (CA). I've tried using what I can find on the Adobe site to create a certificate signed by our CA and configure the Experience Manager to use that certificate but I when try to connect over port 8443 it still creates a self-signed certificate.
I know PTC doesn't support running the AEM 6.3 over SSL but has anyone had any luck (or tried) to configure a turn-key AEM 6.3 installation to use a certificate signed by a CA?
Ok, I got the JBoss in the AEM to run over https using a CA signed certificate. Plus I've been able to apply the reader extensions for markup to drawing PDFs over the https URL. The only thing that I can't get working is having the Office Worker submit its jobs over https. You can enter the port and server but you can't enter the https protocol.
I guess I've gone as far as I can with this post.
