Has anyone used the &pageSize=n URL modifier successfully on the Occurrences table as described in CS Article 281046? (https://www.ptc.com/en/support/article?n=CS281046)
I am trying it in Windchill 10.1 and 11.1 and never getting more than 500 items exported from the Occurrences table when it has ~750 items. PTC says its supposed to work, but I cannot find the magic that makes it work.
-Scott
Hi @ScottMorris
I shared your inquiry with our Tech Support team and they asked for you to submit a case with more details about your issue. There may be a workaround.
Choose: "Open a Case"
Please share anything you can back on this thread for other community members that may be having the same issue.
I have been working with PTC TS on this issue. It appears to be something in our configuration that is preventing this capability from working. I have not been able to find the root cause, but the use of &pageSize=n works on an OOTB installation of Windchill. We have tried to remove as much of the company configuration as possible from one of the test servers, but the problem persists. I will reply when I have more information.
