Attributes with no values cannot be introduced in Document when using Windchill DTI
Alex1988
Please include detailed documentation such as screenshots, images or video.
1. What product and version are you running?
Windchill 13.0.2.8
2. What is the problem?
Unable to insert attributes with no values in Document when using Windchill DTI
3. Are you using a workaround? If yes, please describe it.
No
4. What is the use case for your organization? Describe how your idea would work in context or how it would apply to a practical situation.
Documents in specific states would have attributes without values.
Unaddressed\Not implemented SPR described here - CS373383 - Unable to insert attributes with no values in Document when using Windchill DTI in Windchill PDMLink
5. What impact does this problem currently have on your organization? (Number of users affected, hours of lost productivity, etc.)
Data inconsistency between Windchill PDM Link and the document being opened.
Thank you @Alex1988 for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. What version of the software are you running?.
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
Please see examples of well-documented ideas:
Possibility to mange carry over document relations... - PTC Community
"." and "," - dots and commas - Part usage attribu... - PTC Community
Change Notice Template: Add Pre Prepopulated Assig... - PTC Community
Improve Visualization Behavior for Image Links in ... - PTC Community
Disable Revise Option in BOM Transformer Add Objec... - PTC Community
Catalina
PTC Community Moderator
PTC
