Hi All,
I am using Windchill 10.2 M020 and I am unable to create CAD Documents directly in the Workspace. I create it only using creating WTParts with create CAD Documents option. When directly creating CAD Documents then gives the following errorr.
java.io.IOException: tmpFile.renameTo(classFile) failed at org.apache.jasper.compiler.SmapUtil$SDEInstaller.install(SmapUtil.java:204) at org.apache.jasper.compiler.SmapUtil.installSmap(SmapUtil.java:163) at org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:483) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:378) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:353) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:340) at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:657) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:357) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:749) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:487) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:412) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:339) at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:238) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:264) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1208) at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:992) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:939) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:856) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:936) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:827) at javax.servlet.http.HttpServlet.service(HttpServlet.java:621) at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:812) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:98) at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:249) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1650) at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:409) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:200) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:744) at org.apache.tomcat.util.threads.TaskThread.run(TaskThread.java:77)
kindly help.
It looks like the error is occurring while Tomcat is trying to compile a JSP file. This could be caused by something like a virus scanner locking the file while Tomcat is trying to compile it. Are you running any Anti-Virus software on the Windchill server? If so, try excluding the Tomcat cache from scans, and see if that resolves the error.
Thanks a lot.
Appreciated.
